Download
Buy
Upgrades
Getting Started - Exporting Media Files
CrazyTalk now offers the useful feature of exporting your model and animation scripts to various types of multimedia formats. CrazyTalk now supports AVI, Real Media (RM), BMP, WAV, TGA, Sequence BMPs, Animation GIF and Windows Media (WMV) files.
Note: If you want to export WMV file format from CrazyTalk, you need to install WMVEncoder9 first from the Microsoft website.
To export media, do the following:
  1. Select a CrazyTalk model for your media file and specify its facial features, type of motion, expressions, etc.
  2. Create a CrazyTalk script to specify the animation and speech for the media file.
  3. Click the Media tab under Output to start exporting to multimedia.
  4. A red crop box is displayed on the model. Using the moving tools, move it over the image to decide which portion of the image is exported. Resize the box to specify the output frame size. You can also resize the cropping frame using the Output Size option.
  5. Scroll through the Format drop-down box to select the output media format. Various formats such as AVI, RM (Real Media streaming format), WMV (Windows Media), Sequence Image (BMP or TGA), Animation Gif or audio (WAV) are available.
  6. Check the Export Selected Sequence if you want to export the selected part of the timeline to media format.
  7. Check the Original Resolution option if you want to retain the same resolution as the source file.
  8. Check the Target Resolution option if you want to specify your own target resolution. Select the required resolution from the drop-down box. You can set the resolution for DVD or VCD with PAL or NTSC formats as well as select various other resolutions for Windows media formats.
  9. Check the No Crop option if you want to display the complete talking image without any cropping from the sides.
  10. Check the Crop option if you want to crop talking image on the sides.
  11. Click the Background Color box to select the background from the color palette.
  12. Specify the dimensions of the output frame by entering the height and width in pixels under Output Size.
  13. Enter the frame rate in frames per second in the Frame Rate box.
  14. The HTML options are available if you select a RM file from the media format.
    • Check the Produce HTML Page to create an HTML page with the media content (RM and WMV format only) embedded in the file. The HTML file is saved in the same location as the media file.
    • Check the Preview HTML Page to preview the HTML page before exporting.
  15. Click the Export button to export the selected talking image to multimedia format. Specify the name and location of the exported file and click Save when done.
Creating a CrazyTalk Model
Exporting for Web
Creating a CrazyTalk Script
Sending a CrazyMessenger Export for Mobile Devices
Sending a CrazyCard
<font color="#CCCCCC" face="Arial, Helvetica, sans-serif" size="2"> <p><CrazyTalk is an innovative and easy-to-use software tool for creating animated talking messages from any still digital image or digital photo. Images are brought to life by morphing and appearing to lip-synch with recordings of your own voice, imported audio files or text messages. Messages can be sent as animated greetings cards, instant talking messages, sent as talking email or as an interactive web assitant or virtual host></p> <a class="link_ct" href="https://www.reallusion.com/crazytalk/ct_gallery.asp"><View our Talking Image Gallery></a> <a class="link_ct" href="https://www.reallusion.com/crazytalk/download.asp"><Download free trial of CrazyTalk Home Edition or CrazyTalk Web Edition></a><br> <a class="link_ct" href="https://www.reallusion.com/crazytalk/ct_features.asp"><View the CrazyTalk features which help to make your images talk by morphing and lip-syncing></a><br> <a class="link_ct" href="https://www.reallusion.com/crazytalk/ct_showcase.asp"><View the CrazyTalk Showcase which shows examples of how CrazyTalk can be used as an interactive host on your web site></a> <p><CrazyTalk Web Edition has all the features of the Home Edition with the addition of being able to create interactive talking content for your web site. Talking messages can be exported using .wmv & .rm streaming media formats which can be directly published on your website or imported into tools like FlashMX. For truly interactive content the ActiveX web player can be controlled by JavaScript giving you the ability to react to user driven events.> </p> </font>
