zpr files and not ztl files only work with posetools
Wow, I just figured out that the posetools in zbrush only works while working with a zpr file. I was trying to make it work with a ztl and kept getting the attached image error that would fuck up posetools in zbrush to the point that the file needed to be closed and reopened. And this also happened while using the script in cc5 for zbrush pose link. The file would not send over from cc5 using the script in plugins. Funny enough goz plus kind of works but once you get the pose as a layer and try to modify it it gest the same error when trying to save the edited pose. Don't know if you guys are working on this or not or need to put a disclaimer about it so other poor souls like myself don't go crazy trying to figure out what is wrong. Rampa told me to send this your way. Thanks for making a kick ass app! wow
Hi,
I tested both the ZPR and ZTL formats, and in both cases the props were successfully sent from ZBrush 2026.1.1 to CC. No messages or warnings appeared during the process. Please refer to the attached video for details.
Could you please provide the specific steps so that we can help clarify the issue as quickly as possible? Thank you.
Soya
Reallusion
Need the steps how you create the ztl and how do you load it, also how do you rename the subtools.
I tried to create ztl with the default name of the demoSoldier, loading the ztl after zbrush opened and send current pose from CC5 seems working correctly.
You are going to edit a submitted issue. This issue will be changed to private draft mode until you click submit again. Are you sure?
