I attatched some images of the problems I'm facing recently. "neck_mesh" - This happens with all imported HD Characters from CC5. It extends over the back of the head to the top skull. Only the Face region down to the chin and the rest of the body have the correct textures applied to them. The Scar seems to be missing the normal map and is also using the micro-normals of the skin itself layered on top. "wireframe_body" - This only happened recently - extending to every character, even newly generated HD Base ones. It looks like it has the wireframe as a normal map all over the body. "black_smear" - Those are appearing under the eyes, on each side of the top skull and as a point on the back of the head. I could replicate this with HD Base Characters when I open the Makeup/Skin Editor, import anything and change the Mixer resolution back to 4k before exiting (to retain details). After importing in Blender they appear. Only when I leave the Mixer resolution at 2k I get normal results.
I already contacted Support and the Forum of the Pipeline Plugin afterwards and was now pointed here. I hope I just accidentaly changed some settings, which I can easily fix.
Hi OlDoodX,
Thank you so much for providing the project file via the private comment.
We have tested your file on our end, but currently, we are unable to reproduce the texture and material issues (such as the neck mesh distortion, wireframe normal maps, and the black areas) that you described. The character appears to render correctly after being imported into Blender in our environment.
To help us figure out why this is only happening on your end, could you please confirm the exact versions of the software you are using?
Your current Blender version.
The exact version of the CC/iClone Blender Pipeline Plugin (Auto Setup) you have installed.
Sometimes, using an outdated version of the import plugin can cause these specific material assignment errors.
We look forward to hearing from you so we can get to the bottom of this!
Best regards,
Kayla
Reallusion
OlDoodX
Private Comment
OlDoodX
Private Comment
Feedback Tracker Admin
Hi OlDoodX
Thank you for providing the details of the issue.
To help us identify and resolve the problem more efficiently, we kindly ask you to share the project file or related resources where the issue occurs.
If you have any concerns about file privacy, you may set your message as private, ensuring that only our technical support team will be able to access it.
Kayla
Reallusion
You are going to edit a submitted issue. This issue will be changed to private draft mode until you click submit again. Are you sure?
