Download
Buy
Upgrades
Facial Fitting
  • How can I fine-tune the model image for more realistic facial movement?
  1. The control point 1, 2, 3 and 4 are the key to control the facial mesh morphing. 1, 2 control the vertical movement strength and 3, 4 controls the horizontal movement strength.
  1. Press Motion Settings on model page and checked the Head Motion Preview can preview the movement. If not perfect, you can close the dialog and try to change the location of control point 1-4.
  • How can I make the chin moving more naturally while talking?
  1. Drag the chin control point out of the face.
    Good
    Bad
  1. Continue using Head Motion Preview to preview the result, and drag down the mouse to preview the mouth open while lower the head.
  1. The outline control points should keep to the outside of the facial area.
Select the complete facial outline by clicking the wire frame, not the control points, of the facial outline Then use the Scale button to resize the entire facial outline so that it lies completely outside the subject's face.
Incorrect
Correct
  1. Increase the overall facial movement area.
Expand the edges of the forehead, chin, right and left ears. These four points control the movement area when the image is animated. Edit each point's location to test for proper effect. Select the facial outline and enlarge using the Scale function for a uniform resize of the facial movement area. Increase the strength of the shoulder movements by dragging down the edge of the chin control point. If you want to make the subject's hair or hat move, drag up the forehead control point.
Correct
Correct
  • How can I fine-tune the blinking movement for a more realistic effect?
Edit eyebrow area for a natural blinking action. Click the control line of the eyebrow and drag it up. If the eyebrow is too low, it may cause distortion when blinking.
Incorrect
Correct
  • How can I make the eyes look more real?
If you are not using virtual eyes, but retaining the eyes in the original picture, move the control points outside the eyelids to create an even more realistic blinking action.
Incorrect
Correct
If you are using eyes from the CrazyTalk eye library , you need to set the eye control points inside the eyelids This improves the realistic quality of the animated eyes.
Incorrect
Correct
  • The talking model's eyes always appear to be distorted. How can I remove the distortion?
Refer to the previous two tips to see how to fit the eye and eyebrow control points. If the distortion still persists during blinking movements,click the Auto-Fit Anchor Points button and refit the image. Then make sure to repeat the fitting steps described in the previous two tips to fine-tune the locations of the control points.
  • How can I improve the mouth movements for a photo with an open mouth?
Use the Detailed Facial Mode to keep the upper and lower lips separate. Use the Force to Close function to close the mouth while speaking.
The following illustration shows how to fit an open mouth with the anchor points.
  • How can I avoid background movement without changing the original background?
Use the Background Mask Editing button and spread out the background using the brush and clear tools. Don't get the mask too close to the facial area and make sure that it does not overlap the head of the model.
Incorrect
Correct
  • How can I change the background of the model?
If you want to change the background, first use the Background Mask Editing button and tightly fit the background to the image using the brush and clear tools. Then use the Background Mask Settings button to choose a custom background.
Incorrect
Correct
  • How can I quickly adjust the position of the eyes and the teeth using the Advanced Detail Settings?
When editing the position of the teeth or eyes using Advanced Facial Settings, keep the p/q/t/u arrow buttons pressed down to quickly set the position of the selected feature.
  • How can I used the Close Mouth Points feature to speed up the facial fitting?
When you press the Close Mouth Points button, the mouth will snap shut causing the points for the upper and lower lip to move together in a single line. If your character has a closed mouth, enable this feature so no dark line is visible between the lips while the mouth is closed. If your model has an open mouth, disable this feature so you can fit the points to the upper and lower region of the lips
Before closing
After closing
  • How do I know which control point is the upper or lower control points?
Control points that are yellow in color indicate that they are the upper control points.
Control points of the eyelid
Control points of the upper lip
  • How can I disable head and shoulder movements?
Uncheck the Head Movement and Shoulder Movement from the Motion Settings to disable head and shoulder movement.
General Tips Facial Fitting Script Editing Exporting Keyboard Shortcuts
<font color="#CCCCCC" face="Arial, Helvetica, sans-serif" size="2"> <p><CrazyTalk is an innovative and easy-to-use software tool for creating animated talking messages from any still digital image or digital photo. Images are brought to life by morphing and appearing to lip-synch with recordings of your own voice, imported audio files or text messages. Messages can be sent as animated greetings cards, instant talking messages, sent as talking email or as an interactive web assitant or virtual host></p> <a class="link_ct" href="https://www.reallusion.com/crazytalk/ct_gallery.asp"><View our Talking Image Gallery></a> <a class="link_ct" href="https://www.reallusion.com/crazytalk/download.asp"><Download free trial of CrazyTalk Home Edition or CrazyTalk Web Edition></a><br> <a class="link_ct" href="https://www.reallusion.com/crazytalk/ct_features.asp"><View the CrazyTalk features which help to make your images talk by morphing and lip-syncing></a><br> <a class="link_ct" href="https://www.reallusion.com/crazytalk/ct_showcase.asp"><View the CrazyTalk Showcase which shows examples of how CrazyTalk can be used as an interactive host on your web site></a> <p><CrazyTalk Web Edition has all the features of the Home Edition with the addition of being able to create interactive talking content for your web site. Talking messages can be exported using .wmv & .rm streaming media formats which can be directly published on your website or imported into tools like FlashMX. For truly interactive content the ActiveX web player can be controlled by JavaScript giving you the ability to react to user driven events.> </p> </font>
