Download
Buy
Upgrades
Exporting
  • How do I embed CrazyTalk models and scripts to MS Office documents or PowerPoint presentations?
    1. Export the Script and Model data to your hard disk using the Export Data button on Web page.
    2. Open MS PowerPoint and click View > Control Box to open the Control Box.
    1. Click More Controls and choose CrazyTalk4 Control.
    2. Drag and create an area where you want to insert the CrazyTalk image.
    3. Right-click the area and select CrazyTalk4 Control Object > Properties to open the property settings.
    1. Choose the Model and Script you exported.
    2. Press OK and play the slide show to display the CrazyTalk image.
Note: If you want to use the PowerPoint file on a different computer, you need to check the Embed Data to Document option or copy the CTS and CTM files to the target computer.
  • How can I reduce the model and script size when exporting for web?
If you want to reduce the model size, use the original eyes, background and no teeth when you edit the model. On the web page, choose a lower quality setting to reduce the size.
For reducing the size of the script data, you can choose a lower quality setting and remove some unneeded special effects from the timeline.
  • How can I reduce the exported data size while burning VCDs or DVDs?
For lower data size when exporting to media, export to RM or WAV with a higher quality setting or use AVI codecs that are easily available on the Internet. (e.g. Panasonic DV Codec) After downloading it, right-click the INF file to install it. When you export to AVI, choose the codec you just downloaded from the Target resolution.
General Tips Facial Fitting Script Editing Exporting Keyboard Shortcuts
<font color="#CCCCCC" face="Arial, Helvetica, sans-serif" size="2"> <p><CrazyTalk is an innovative and easy-to-use software tool for creating animated talking messages from any still digital image or digital photo. Images are brought to life by morphing and appearing to lip-synch with recordings of your own voice, imported audio files or text messages. Messages can be sent as animated greetings cards, instant talking messages, sent as talking email or as an interactive web assitant or virtual host></p> <a class="link_ct" href="https://www.reallusion.com/crazytalk/ct_gallery.asp"><View our Talking Image Gallery></a> <a class="link_ct" href="https://www.reallusion.com/crazytalk/download.asp"><Download free trial of CrazyTalk Home Edition or CrazyTalk Web Edition></a><br> <a class="link_ct" href="https://www.reallusion.com/crazytalk/ct_features.asp"><View the CrazyTalk features which help to make your images talk by morphing and lip-syncing></a><br> <a class="link_ct" href="https://www.reallusion.com/crazytalk/ct_showcase.asp"><View the CrazyTalk Showcase which shows examples of how CrazyTalk can be used as an interactive host on your web site></a> <p><CrazyTalk Web Edition has all the features of the Home Edition with the addition of being able to create interactive talking content for your web site. Talking messages can be exported using .wmv & .rm streaming media formats which can be directly published on your website or imported into tools like FlashMX. For truly interactive content the ActiveX web player can be controlled by JavaScript giving you the ability to react to user driven events.> </p> </font>
