[Unreal Live Link] Prop sent UE5 -> iClone 8 -> UE5 arrives at a wrong position. Bug, or is there a workaround?
Hello Reallusion team,
I would like to ask whether the following behavior is a known bug, or whether there is a recommended workflow to avoid it.
Environment
- iClone: 8.75
- Unreal Engine: 5.8
- Unreal Live Link plugin for iClone: [newest ver]
- OS: Windows 11
Steps to reproduce
1. In UE5, I send a static mesh (prop) to iClone 8 using the Live Link transfer function.
2. The prop appears in iClone 8, but it is not linked to the original actor in UE5. Moving or animating it in iClone does not move the original mesh in UE5.
3. To get a linked prop, I send the same prop from iClone 8 back to UE5 using the Live Link transfer function.
4. The prop that arrives in UE5 is placed at a completely wrong position, different from its position in iClone and from the original position in UE5.
Expected result
The prop arrives in UE5 at the same position (and rotation/scale) as in iClone, so that it can be used as a linked prop.
Actual result
The transform of the re-transferred prop is badly off, so the coordinates are effectively scrambled.
Additional note
When a mesh is sent from UE5 to iClone, it arrives without its materials, so the mesh sent back to UE5 also has no materials. This is why I cannot simply reuse the original actor, and I need a way to drive the original UE5 mesh from iClone.
Questions
1. Is this position problem a known bug?
2. Is there a recommended workflow for round-tripping a prop from UE5 to iClone and back to UE5 while keeping the correct coordinates ?
3. Is there a way to connect an existing UE5 actor to an iClone prop via Live Link without re-transferring the prop?
Please watch the video.
https://youtu.be/ajjB3KXm484What I want to do
I am animating a character standing up from a chair in iClone 8. At the moment the character stands up, I also want to animate the chair at the same time in iClone (for example, the chair moves back as the character stands). I want this chair animation to be reflected in my UE5 level through Live Link.
My plan is as follows. The chair that comes back from iClone 8 to UE5 has lost its materials, so I do not want to use that mesh as it is. Instead, I want to use the Live Link-driven prop from iClone 8 only as a driver: I will attach my original UE5 chair (with its materials, as part of the level) to the linked prop, and hide the mesh that was sent from iClone 8. This way the original chair keeps its materials and moves together with the character.
Thank you for your time.
