Votes
0
Product:
iClone 8
Version:
8.75
Status:
Not Reproducible
Issue 12716
No longer able to import external animations (motions) correctly.
In previous versions of iClone you were able to create a character (e.g. within CC4), Send To iClone and also export this as an FBX to 3dsmax. You then use the Reallusion plugin (inside 3dsmax) to import the fbx and add a Biped Rig. You animate that rig and export the animation as an FBX. This fbx file could then be dropped back onto the original model within iClone8 and then sent back to CC4. Now when I repeat that process (in CC5, an updated CC4 and iClone 8) the animations don't work, either the targeting or the entire animation fails. The closest I can get moves major limbs (incorrectly), but fingers etc are ignored. This used to be a simple process, I've even tried using the Characterization mode to manually select/match the bones (which I also did not have to do previously). Even after this, the model does not animate correctly and just floats around. It's like the program no longer understands the 3dsmax rigs correctly. I've also tried a CAT rig, which also worked previously, but fbx files using CAT rigs are now rejected completely and iClone 8 doesn't identify the motion profile at all. Finally I also tried downloading a Mixamo fbx (without skin) and that also doesn't work.
OS: Windows 11
  •  1
  •  123
Submitted byjlb_288387
COMMENTS (1)
Feedback Tracker Admin
Hi jlb_288387,
Thank you for the detailed report. We understand how frustrating it is when a previously working pipeline breaks.
To help our development team accurately reproduce this issue and identify the root cause, could you please provide the following?
   1. A Screen Recording: A video demonstrating your exact workflow (from exporting/animating in 3ds Max to importing the FBX back into iClone 8/CC5) so we can see how the animation fails or floats.
   2. Project Files: The original character FBX and the animated FBX file you are trying to import.
If the files or video are too large to attach directly to this ticket, please feel free to upload them to a cloud service (such as Google Drive or Dropbox) and share the download link with us.
Thank you for your time and assistance!
Kayla
Reallusion
Hi jlb_288387,
Just following up on this issue. We are still eager to help you investigate the animation import problem, but our development team needs your files to proceed.
Could you please provide the screen recording and the FBX project files mentioned in our previous message? If the files are too large, sharing a cloud storage link (such as Google Drive or Dropbox) works perfectly.
If you have already found a workaround or no longer need assistance, please let us know. We look forward to hearing from you!
Kayla
Reallusion
