Votes
Product:
Character Creator 4
Version:
4.74
Status:
Assigned
Issue 12744
Major (DAZ) Mesh Distortion and Collision Bugs After Latest CC Update
When I import a figure from Daz, I run into a lot of issues making adjustments afterwards. Sometimes, Daz hair that I convert into hair in CC changes sometimes, looking as if you stuck your finger in an electrical socket.
I also notice that clothing items react to one another. If you remove a piece of a tracksuit or add something new, the rest of the outfit shifts or changes slightly as well.
The Hide Body Mesh tool acts strange too; when I have a clothing item or other clothes, they look smooth. But if I delete the clothing piece that was modified with the Hide Body Mesh tool, the other clothing items suddenly become completely distorted.
All in all, after this latest update, it is almost impossible for me to work with this anymore.
OS: Windows 11
  •  6
  •  192
Submitted bythat other guy
1 2
COMMENTS (6)
Joanne (RL)
Hi ,
[ Issue 1 ]
Currently, characters imported via Transformer FBX default to Tuck-in mode, with Collision set to ON by default. Looking at your project, all clothing items are stacked closely together, causing CC to calculate cloth collision for all layers at the same time.
Suggested Solutions:
https://www.youtube.com/watch?v=Mlui3IOB0jI
1. Move underwear to the innermost layer (as shown in the first half of the video).
2. Turn Collision OFF for clothes that don't need calculation (as shown in the second half of the video. If all items have Collision ON, clipping will confuse the collision calculation).
[ Issue 2 ]
As mentioned earlier, CC5.2 / CC4.74 automatically runs Conform Collision because of the Tuck-in feature—this happens every time you apply clothing if the Collision is ON. Therefore, after you finish editing the shape, please click Set as Default.
https://www.youtube.com/watch?v=PIbXuUeXvQc
(This makes CC use the current mesh data for collision calculations.)
Why it works this way:
Currently, you need to manually click the button to update the default data. If CC automatically updated defaults whenever you saved, data would stack and accumulate when applying the item to characters with different body shapes.
For more detailed information, please check our [Content Wiki].
https://wiki.reallusion.com/Content_Dev:CC_Clothing_Default_Settings
We are still discussing this workflow design internally, as the current steps are a bit tedious and inconvenient. For now, please follow the workaround provided above. Hope this helps!
that other guy
Private Comment
Feedback Tracker Admin
Hi that other guy,
Thank you for providing the link and video! I have received the files and will pass them to our team for further investigation.
Best regards
Kayla
Reallusion
that other guy
Well, a new thing, I turned Eneble Conforming off, and Used edit mesh on these cloth.
But when I added assasorys,  I find out things went back before I edit the mesh.....
that other guy
Hi, Feedback Tracker Admin
I send a dropbox link to feedbacktracker@dmt.reallusionnews.com
@ Joanne (RL)
Thats works, thanks
Hi that other guy,
Thank you for taking the time to upload the files and for providing the additional information regarding the Edit Mesh behavior! We have noted this new detail.
Regarding the Dropbox link, it seems you sent it to our automated system email, which our QA team cannot directly access.
Could you please share the Dropbox link directly here in the comments?
To protect your privacy, you can check the "Private Comment" box before you post. This ensures that only our Reallusion admin team can see your link and files, and they will remain hidden from other users.
Looking forward to your link so we can dive into the project file. Thank you again!
Kayla
Reallusion
Hi that other guy,
Following up on Joanne's reply, we are also actively investigating the other issue you mentioned regarding the "Hide Body Mesh" tool causing distortion when deleting clothing.
Our QA team has run several tests on our end, but we haven't been able to trigger the exact mesh distortion shown in your screenshots. Since imported DAZ characters and their clothing often have highly unique topologies and configurations, the issue might be specific to this particular asset setup.
To help us narrow down the root cause, could you kindly provide the following?
  1. A short screen recording: Showing the exact sequence of actions (applying the hide mesh, and then deleting the cloth) right up to the moment the distortion occurs.
  2. Your Project File (.ccProject): The project saved just before you delete the clothing, so we can test the exact same mesh data.
If the files are too large to attach here, please feel free to use a cloud service (like Google Drive or Dropbox) and share the link with us. Thank you so much for your patience and for helping us track this down!
Kayla,
Reallusion
1 2
