Votes
0
Product:
Character Creator 5
Version:
5.13
Status:
Not Reproducible
Issue 12687
Headshot 3 within CC5 does not transmit the final AI Genrative completion to the main display. Instead it tries to use the CC3 Base figures.
When following the Tutorial (Proven Stylized Character by Antony Evans from Digital Puppets UK) Headshot 3 works fine up to the last button where the selection is displayed in the main window. Instead of displaying the Headshot 3 completion, it reverts to the CC3 default and not the HeadSHOT 3 processed (using the AI Generation).
OS: Windows 11
  •  1
  •  179
Submitted bytxguy5199
COMMENTS (1)
Feedback Tracker Admin
Hi txguy5199,
This is not a bug or a failure in AI generation transmission; rather, it is the expected workflow for stylized characters in Headshot 3.
Because stylized characters feature exaggerated facial proportions (such as large eyes), the AI Mesh Generator only establishes an initial base mesh conforming to standard CC topology during the first pass. As a result, the freshly generated model initially looks close to the default base figure. To fully transfer and deform the mesh into your stylized character, you need to use the Refine Face tool:
  1. Access the Adjustment Panel: Once mesh generation completes, navigate to the Shape Adjustment section on the left panel and click Refine Face (Look).
  2. Align Feature Points: In the pop-up Refine Face window, select the eyes and facial contour points, then manually drag the green landmark points to match the boundaries of the large stylized eyes.
  3. Apply the Deformation: Click Apply Current Parts or Apply All at the bottom right. The 3D mesh in the main viewport will immediately update and conform to the stylized proportions.
  4.  Side Profile Calibration: It is also recommended to use Refine Face Side to properly align facial depth and side contours.
You can check out Antony Evans' official demonstration in this tutorial: https://www.youtube.com/watch?v=4jOlQUu6vGg
[05:42]: Demonstrates how the model initially appears after generation before manual refinement.
[06:04]: How to open Refine Face Front and reposition the facial landmarks.
[06:57]: Demonstrates clicking Apply All to deform and update the viewport mesh.
Following these refinement steps will properly shape the character to your stylized design.
Please feel free to reach out if you have any further questions or need additional assistance.
Kayla
Reallusion
Hi txguy5199,
Just checking in on this issue!
Did the steps and the video tutorial provided in our previous reply help you successfully refine the mesh and achieve the stylized look in the main viewport?
If you have any further questions or run into any trouble during the refinement process, please let us know. If we don't hear back from you within the next 7 days, we will assume the issue is resolved and temporarily close this ticket. You can always reopen it by replying here later.
We look forward to hearing from you!
Kayla
Reallusion
