Character moved up and is now floating a little bit above the Pivot/Origin point.
- Created a character using Headshot3 (using child body) - Changed character little bit with Morphs - Saved character to use as a standard for the new characters i want to create - Now with the standard character open i change the face images in Headshot3 to create a new one - Body settings in Headshot3 are 'Current'. - New face/hair gets generated (on a side note....this crashes sometimes at 95% but restore works) - now looking at the floor 0,0,0... the new character created floats above it.
Hi g.j.verheij
We are currently unable to reproduce this issue on our end. It may be related to the content or morphs you have applied, so we would need some additional information to investigate further.
Could you please provide a complete screen recording of your workflow? Ideally, please include both the initial save, when the character appeared normal, and the subsequent save, when the character started floating.
You can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment. You can use Private Comment if you want to keep it private.
This would help us better understand the issue and identify its root cause.
Thanks
Steven
You are going to edit a submitted issue. This issue will be changed to private draft mode until you click submit again. Are you sure?
