Votes
0
Product:
Character Creator 5
Version:
5.2
Status:
Not Reproducible
Issue 12742
CC 5.2 – Missing FBX Mesh Merge Dialog Affecting Multipart Clothing
Hello. I hope you're doing great. I'm facing the issue described below.
After updating to Character Creator 5.2, the dialog asking whether to merge meshes or keep them separate no longer appears when importing an FBX through Create -> Accessory.
My clothing is created in Blender using multiple independent components (bodice, sleeves, cuffs, etc.), joined into a single mesh object before FBX export.
Previously, the import dialog allowed me to control how these components were merged. Now, the garment imports as one accessory, but after transferring skin weights, its individual components visibly separate during character animations.
Troubleshooting performed:
Tested both Default and Cloth skin-weight presets — neither resolved the issue.
Mesh -> Merge Mesh is greyed out.
Modify -> Merge Accessory is unavailable.
Tested different animations, with visible gaps appearing between sleeves, bodice and cuffs.
Steps to reproduce:
Join multiple garment components into one mesh object in Blender without welding their vertices.
Export as FBX and import through Create → Accessory.
Transfer skin weights and apply an animation.
Observe the separation between garment components.
Could you please confirm:
- Was the previous mesh merge/separation dialog intentionally removed in CC 5.2?
- Is there another way to access this functionality?
- Could the change be related to the observed clothing deformation?
Screenshot demonstrating the problem are attached.
Thank you very much for your assistance.
OS: Windows 11
  •  4
  •  84
Submitted bys1mone.g
COMMENTS (4)
s1mone.g
Hello Joanne,
Thank you so much for taking the time to investigate this!
I tested the Vertex Mode as you suggested, and it worked perfectly! All clothing components now stay together and deform correctly during animations.
I really appreciate your help and the clear explanation. Thank you again!
Joanne (RL)
Hi,
I tested the FBX file you provided in CC5.13 (previous version), and there was also no popup dialog asking whether to merge meshes.
That is because the meshes were already joined into a single mesh object prior to exporting the FBX. As you can see in the attached Image 1, there is only a single mesh node (mesh.008), the popup dialog you mentioned only appears when the importer detects multiple mesh nodes.
Additionally, because your asset consists of multiple separate elements (close vertices are not welded together)  (as shown in Image 1), we recommend enabling Vertex Mode under Transfer Skin Weights (Image 2).
Vertex Mode is specifically designed for assets composed ofmultiple separate elements where vertices are not welded together.
Joanne
s1mone.g
Private Comment
Feedback Tracker Admin
Thank you for your feedback.
To help us investigate this issue, could you please provide the FBX file used to reproduce the issue?
You can use cloud services such as Google Drive, Dropbox, or OneDrive to share the file. If you prefer to keep it private, you can share the link in a private comment.
Thank you for your cooperation.
Allen
Reallusion
