Hi Marani, You can refer to these videos below for step-by-step guides 🎬 Recommended Video Tutorials To make this easier to follow, you can check out these useful community tutorials that demonstrate these exact principles: • How to build dummy collision shapes for irregular props: https://www.youtube.com/watch?v=jawvNr1p23s • How to fine-tune soft cloth physics settings & margins: https://www.youtube.com/watch?v=nF7tQVrg1FY • How to apply Spring & Soft Physics to Prop/Bone hierarchies: https://www.youtube.com/watch?v=Yg5CcQg7RQo We have officially documented your case and passed this along to our development team for future physics simulation improvements. If you encounter any difficulties setting up the dummy shapes or working with prop-based physics, please let us know so we can further assist you. Kayla Reallusion
Hi Marani, Thank you for the detailed feedback and the annotated screenshot! Seeing your clear markers (1, 2, and 3) is incredibly helpful for us to understand your exact setup. After reviewing your case, we can confirm that this behavior is due to a fundamental limitation of the underlying physics engine (NVIDIA PhysX): Soft Cloth simulations do not support collisions with "Self-Mesh" or "Convex Hull" bound types. When these bounds are used, the cloth will ignore them and fall straight through (as seen at position 1). Soft cloth physics can only successfully collide with basic primitive shapes like Box, Sphere, and Capsule (as seen at positions 2 and 3). We completely understand that you want the cloth to naturally drape over your custom uneven terrain. While this limitation exists, you can achieve the exact visual results you need by using the following industry-standard workarounds: 💡 Workaround A: Use Composite "Dummy" Primitive Shapes (Highly Recommended) 1. Go to the top menu and select Create > Primitive > Sphere (or Box / Capsule). 2. Scale, rotate, and place multiple primitives over your irregular props to manually mimic the contours of the hill surface. 3. Go to the Modify panel > Physics tab for each primitive. Check Activate Physics, set the Object Type to Static or Kinematic, and ensure the Bound Type matches the shape (Sphere or Box). 4. In the Scene Manager, attach all these primitives to your main terrain prop so they stay grouped. 5. Hide the primitives by toggling off their visibility (the eye icon) or setting their opacity to 0. 6. Reset the timeline to frame 1 and hit Play. The soft cloth will drape over these hidden shapes perfectly, giving the illusion that it is molding to your custom terrain. 💡 Workaround B: Fine-Tune the Simulation Settings • Switch to "By-Frame" Mode: Always change your timeline playback from Realtime to By Frame mode when calculating physics. This gives the engine enough time to calculate precise collisions and prevents the cloth from snapping through objects. • Increase Collision Margin: If the cloth slightly penetrates the shapes, select the soft cloth, go to Physics > Soft Rigid Collisions, and increase the Margin value slightly to push the cloth further away from the contact surface. 💡 Workaround C: Use Prop-Based Grass for True Interactivity If your goal is to have characters or objects physically interact with the grass itself (e.g., bending or trampling), please note that iClone's built-in landscape foliage generator does not support individual physics collisions. To achieve true collision effects, you need to use grass that is imported or converted as an actual "Prop" asset. Once treated as a Prop, you can assign Soft Body physics or Spring Bone structures to the grass models, allowing them to bend naturally under weight. Kayla Reallusion
