Votes
0
Product:
Character Creator 5
Version:
5.2
Status:
Assigned
Issue 12735
Corrupted UV mapping using Quad remesher
The Quad Remesher alters the UV map from the original. This makes all the original texture maps created for the item useless. It also destroys the weight mapping
I've tried all combinations of tick boxes all result in the same remapping from the original UV map
The remapping of the UV is also not consistent, I remapped an item, then deleted it, reloaded the same item and remapped it a second time.
The second UV map is different from the first map
The apparent random remapping also makes it almost impossible to create weight maps
see the images
OS: Windows 10
  •  2
  •  63
Submitted byblindman
COMMENTS (2)
blindman
You've just told me what I already know !
This makes the remesher useless for existing items, which is what it's best used for,  as new items can be built from quads to start with
The random nature of the UV  layout as well as it's lack of repeatability, adds a significant amount of time to the work flow, It makes the recreation of weight maps unnecessarily complicated and requires  every texture to be reworked
It wouldn’t  be so bad if after the remesh the UV could at least be edited to limit the damage done to the original UV
It's quicker and easier to use existing third party software to quad which  preservers the original UV,
So Reallusion's poorly implements a function which causes more problems that it solves and its response is basically telling  users "HARD LUCK deal with it"
Feedback Tracker Admin
Thank you for your feedback.
Quad Remesher generates a new mesh with its own UV mapping. It does not preserve the original UV layout from the source mesh.
Therefore, the UV mapping and original texture maps may no longer be compatible with the remeshed model.
Allen
Reallusion
