Votes
0
Product:
Cartoon Animator 5
Version:
5.34
Status:
Active
Issue 12731
Cartoon Animator 5 Bug Report – Applying Face Motion or Perform Deletes Existing Voice and Lip-Sync
Dear Reallusion Support Team,
I am experiencing a potential bug in Cartoon Animator 5 where applying a saved Face Motion or Perform clip deletes or overwrites the character's existing voice and lip-sync animation.
I have tested this issue multiple times using different export methods, and the problem occurs consistently.
I have also attached two screenshots showing the Timeline before and after applying the Eye Blink animation.
Test 1: Exporting Body Motion + Eye Blink as Perform
I created a body motion animation along with an Eye Blink animation using the Eye Sprite Editor.
I used Collect Clip → Export Perform to save both animations together as a custom Perform template.
I selected another character that already had voice and lip-sync animation.
I applied the saved Perform clip at a specific frame in the Timeline.
Result:
The existing voice and lip-sync are removed starting from the exact frame where the Perform clip is applied.
The voice and lip-sync before that frame remain intact, but everything from that frame onward is overwritten or disappears.
Test 2: Exporting Eye Blink as Face Motion Separately
To determine whether the issue was caused by the Perform clip, I conducted another test.
I exported the Eye Blink animation separately as a Face Motion clip.
I selected a character that already had a complete voice recording and automatically generated lip-sync.
I applied the saved Face Motion clip starting at Frame 20.
Result:
The same issue occurred even without using a Perform clip.
The voice and lip-sync before Frame 20 remained intact, but the voice and lip-sync from Frame 20 onward disappeared.
This suggests that the issue may be related to how saved Face Motion clips interact with existing Voice Clips.
Attached Screenshots
Screenshot 1 — Before Applying Eye Blink (Befort apply eye blink.jpg)
This screenshot shows the original Timeline before applying the Face Motion clip.
The complete voice waveform is present throughout the dialogue.
The corresponding lip-sync/viseme keys are visible.
The voice and lip-sync are working correctly.
Screenshot 2 — After Applying Eye Blink (After apply eye blink.jpg)
This screenshot shows the Timeline after applying the saved Eye Blink Face Motion at Frame 20.
The Eye Blink animation appears on the Facial Clip and Face Motion tracks.
A new "Eye_Blink" segment appears on the Voice Clip track.
The voice waveform disappears from Frame 20 onward.
The corresponding lip-sync/viseme keys also disappear from Frame 20 onward.
The voice and lip-sync before Frame 20 remain intact.
The screenshots clearly demonstrate the difference between the Timeline before and after applying the Face Motion clip.
Additional Observation
I also tested applying the Perform or Face Motion animation first and then importing the voice afterward.
In that order, everything works correctly.
However, this workflow is not practical for my animation projects. I need to listen to the dialogue first so I can accurately determine the timing of hand gestures, body movements, facial expressions, and eye blinks.
I also need to reuse custom animation templates across multiple characters without losing their existing voice recordings and lip-sync.
Expected Behavior
Applying a saved Perform or Face Motion clip containing body movement and/or Eye Blink animation should not delete, replace, or overwrite existing voice and lip-sync data.
The previously created Voice Clip and Viseme animation should remain intact.
Questions
Is this a known bug or an intended behavior in Cartoon Animator 5?
Why does applying a Face Motion clip generated from an Eye Sprite animation replace the existing Voice Clip with an "Eye_Blink" segment?
Is there a setting or option to prevent Perform or Face Motion clips from overwriting existing voice and lip-sync?
Is there a way to export Body Motion and Eye Blink together as a reusable custom template without including any Voice Clip data?
If this is a bug, is there a fix or workaround available?
I would greatly appreciate your assistance in investigating this issue.
I have attached the before-and-after Timeline screenshots for reference.
Thank you for your time and support.
Best regards
OS: Windows 11
  •  0
  •  39
Bug
Submitted byMD SHAFIUL ALOM
COMMENTS (0)
