CC4 Crashes when converting Accessory to beard or eyebrows
Steps to produce bug:
Import FBX asset using accessory import Press create hair, brows, beard in the modify panel Reset facial expressions to default
Options tested: Base/All(Hair) Full Beard (Beard) Brows (Eyebrows) Hair works fine without issue but beard and eyebrows start to convert then crashes at 10%
Tried two different FBX's one being a beard one being a default box, both cause the crash.
Hi,
Quick update: the issue you reported is fixed in the latest CC 4.74 - Create Hair, Brows, and Beard works without crashing now.
But, this character file still has some invalid data, which can still cause instability or crashes in other features.
We can't automatically validate/repair the data yet, so we’re rebuilding the character on our end and will provide the clean file to you soon (via private message).
If you have a moment, could you let us know your workflow for creating this character? We haven't figure out how to get this invalid data, so your steps would be super helpful for the dev team.
Thanks a lot for your help!
alexjarrett
Private Comment
Feedback Tracker Admin
Hi alexjarrett,
I have got it. Thank you for your help.
Molly
Reallusion
Hi alexjarrett,
I can't repeat it.Can you provide your character file to help us identify the problem?Please attach the file in your next comment. If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment. You can use Private Comment if you want to keep it private.
Your help is highly appreciated.
Molly
Reallusion
You are going to edit a submitted issue. This issue will be changed to private draft mode until you click submit again. Are you sure?
