Sending the Avatar back to CC5 from Zbrush breaks the mesh or makes it disappear from the viewport. I've reverted back to the previous version so i can continue my work, but cc5 refuses to open now. It seems there's always an issue with the Zbrush pipeline every time you roll out an update. Even the smaller updates cause mini issues that i have to circumvent to get any work done. Please fix.
Using the previous version of cc5, i sent the base mesh F to Zbrush using GoZ (Head split from body), ad matched Zbrush Model scale(x0.01). I modelled the character in Zbrush (Subdivisions up to 6) then sent it back to cc5 as shown in the video.
Feedback Tracker Admin
Hello,
Thank you for providing a more detailed description of the steps.
Based on your description, we were able to reproduce the issue and have submitted a report to our development team for further investigation.
Thank you for your patience and understanding.
Tina
Hi,
Thank you for providing the screen recording.
We have reviewed the video and noticed that it mainly shows the process of sending the mesh from ZBrush back to Character Creator via GoZ.
To help us further investigate the deformation issue, could you please provide some additional details about the steps you took before sending the mesh back to Character Creator?
In particular:
Did you make any changes to the character's scale or size in ZBrush?
Did you perform any other mesh modifications in ZBrush before using GoZ?
Could you briefly describe the workflow from exporting the character from Character Creator to ZBrush up until sending it back?
This information will help our RD team better understand the workflow and identify the possible cause of the issue.
Thank you for your cooperation. We look forward to your reply.
Tina
You are going to edit a submitted issue. This issue will be changed to private draft mode until you click submit again. Are you sure?
