Product: Auto Animation Library
Vol.1
Description:
Auto Animation Library Vol.1 provides you with 3 indispensable additions tocompliment CrazyTalk7's AutoMotion Technology which allows your own voice to drive the intensity of the animation. With hundreds of auto animation templates and styles at your disposal, you'll have no trouble finding the perfect sample templates to give your character the desired movement and expression.
Voice Scripts x 63 See Demo
Use this sound library full of audio clips and preset scripts in any way you like to give your animation that little extra charm. Combine them with custom puppet motion or clip animation layering, then save them in your personalized motion clip library!
Auto Motions x 85 See Demo
With scenario-based auto motions, you can apply any motion styles to accompany any character performance. It also allows you to adjust strength levels to fit each character's unique style. Auto motion is a functional feature that gives the character an initial template motion, which serves as a starting point for the rest of your animation.
Motion Clips x 42 See Demo
The Motion Clip library helps you create intricate expressions, makes your characters perform beautifully, and generally helps to spice up your animation. You can also edit and layer custom motion clips or puppet animations together to create your own unique expressions.
