The direction and position of the Pivot strongly affects the movements of the constrained physics objects because the constraint types are either movement-based or rotate-based. When the pivot of a constrained rigid body is adjusted, the constraint applied to it will be auto-adjusted as well to align to the pivot.
To know more about this characteristic of constraints, make sure you're familiar with the Local Axis of your object.
To show the local pivot, you may follow the steps below:
or
Local Rotate Tool
(toggled by shortcuts W and E).
The move-based or move-related constraints are Slider and Spring. When
an object is given one of these two constraints, the direction of its pivot will affect
the movement behavior of the constraints. The adjustments cause a physics object to
move along a specific direction rather than its default movment pattern.
The table below shows the results before and after the pivot direction adjustments of these objects (connect to either the World or kinematic objects).
Move Limit: Local X |
Initial pivot direction |
The figure below shows the effects before and after the adjustments of the pivots' directions of these objects (connect to dynamic or frozen objects).
The rotate-based or rotate-related constraints are Hinge, Spring, Point to Point and
Cone Twist. When an object is given one of these constraints, the position of its pivot will affect
the rotating behavior of the constraints. The adjustments makes a physics object
rotate around a specific axis.
The table below shows the results before and after the adjustments of the pivots' positions of these objects (connect to either the world or other physics objects).
Rotate Limit: Local Y |
Initial pivot position |
Adjusted pivot position |
The table below shows the effects before and after the adjustments of the pivots' positions of these objects (connect to other physics objects).
