IClone provides several categories of particles for you. You may apply them and then modify the parameters to change the result:
Please click the Set tab in the navigation pane.
Press down the Particle button.
Switch to the template tab. Simply double-click on any one template in these categories and your project generates particles accordingly.
Play back the project to see the result.
As for the other parameters for adjustment, please read the next section:
