DEVICE LIVE & CUSTOM HOTKEYS
Intuitively engage directing and editing with Live Switching, Trigger Effects, Slider fader, Jog Dial timeline scrubbing, Drone camera navigation, and so much more. Almost all functions in iClone can map to custom hotkeys for assigning devices that interact as physical interfaces for ultimate scene control.
Camera Switch & Navigation
Motion & Timeline Editing
3D Object Transformation
Lighting & Perform Triggers
CAMERA CONTROL
Smooth Camera Navigation
  • Navigate 3D scenes with steady camera controls.
  • Familiar Drone Camera Operation - Move, Elevation, Yaw, Pitch, Roll.
  • Freely speed up, slow down, move, and rotate with Runtime Sensitivity triggers.
Fly Camera Mode New in v8.7
Switch to Fly Camera mode and navigate scenes freely using your keyboard and mouse. Move, rotate, and explore from close-ups to sweeping aerial views.
  • Hold the right mouse button to enter Fly Camera mode, control camera direction using WASD and QE keys.
  • Scroll Mouse Wheel to adjust camera movement speed.
  • Automatically record the Fly Camera path when a custom camera is selected.
  • MD Mode: Activate Fly Camera via MD Trigger panel.
Camera Switch & Recording
  • 10 camera switch triggers.
  • Record the camera movement path to a chosen camera track.
  • Camera replay and timeline editing.
  • Key reduction and curve eding.
Camera Lens Adjustment
  • Simulate real-world camera lenses.
  • Adjust focus distance and focal range for depth of field (DOF).
  • Focal Length = Lens type (mm).
  • Camera Look At.
LIGHT CONTROL
Light Switch & Fade
  • Control switching up to 10 lights.
  • Simulate dimmer effect via Light Multiplier.
  • Sliders control Absolute brightness, Endless Jog Dial controls Relative brightness.
  • Additional spotlight controls- Range, Angle, Falloff, Attenuation.
  • Live Link to Unreal engine.
3D OBJECT TRANSFORMATION & MOTION EDITING
Animation Editing
  • Fast and intuitive editing.
  • Adjustable Sensitivity to XYZ axis.
  • Fast traversal between End Effector Controllers.
  • Optimized for 3Dconnexion SpaceMouse®.
Objects Transformation
  • Move, Rotate, Scale selected 3D objects, and optional Lock horizon.
  • Click to duplicate a selected object.
Timeline Scrubbing
  • Paced animation playback.
  • Pan, zoom, and fast scroll through timeline when seeking frames.
  • Adaptive scroll speed according to dial range.
  • Custom hotkey triggers - set key, break, loop, speed, etc.
HOTKEY TRIGGERS
Camera Switch
  • Equip a director console with multi-cam switcher.
  • Up to 10 one-click camera switches.
  • Toggle between Preview Cam and Custom Cam.
Interface Switch
  • Direct jump to your target function with one click of a button.
  • Layout switch.
  • Panel and Tab switch.
  • Session switch.
  • Direct Function Triggers.
FREELY MAP DEVICES TO ICLONE FUNCTIONS
To make iClone more user driven, almost all iClone functions can custom map to user defined hotkeys, especially Windows compatible devices. This open design will fundamentally change the way people work with iClone, or Live Link animation to other 3D tools.
HOTKEY MANIA - SPEEDY CREATION TOTALLY WITH HOTKEYS
Save valuable time and control scenes with swift hotkey action. Take a look this fast animation and see how it’s totally done by using hotkeys.
USING THE SAME HOTKEYS AT DIFFERENT TOOLS
The limited keys on the keyboard may soon cause a hotkey conflict. The intelligent Global and Local hotkey trigger design enables using the same hotkey for different purposes, see how it at work here.
Global
To let the global keys take control, simply click on the 3D viewport, it will escape from the focused interface and resume hotkeys to global.
Local
Once you are highlighting a specific interface, such as Timeline, Modify Panel, or Motion Capture, the local keys will take effect.
GAME-LIKE CHARACTER CONTROL
