Votes
0
Product:
iClone 8
Version:
8.76
Status:
Duplicate
Issue 12722
iClone 8.76 – Drag and Drop Function Not Working
Title: iClone 8.76 – Drag and Drop Function Not Working
Description of the Issue:
After updating iClone from version 8.75 to version 8.76, I encountered a serious problem with the drag-and-drop function.
When I use my mouse to drag and drop any content into the iClone viewport or scene, it does not work. This problem happens with all types of content, including characters, objects, Sky, and other assets.
When I try to drag an item into the scene, iClone freezes for approximately 30–40 seconds and then automatically crashes and closes.
However, if I double-click the content or character, it loads into iClone successfully. This works for all types of content.
The same problem occurs when I try to drag content into the Scene Manager. Dragging does not work, but double-clicking the item loads it successfully.
Expected Behavior:
I should be able to drag and drop any content, character, object, or Sky directly into the iClone scene, just as I could in version 8.75.
Actual Behavior:
The drag-and-drop function does not work at all in version 8.76. iClone freezes for 30–40 seconds and then crashes. Double-clicking content is the only way to load it successfully.
My System Information:
Software: iClone 8.76
Previous Version: iClone 8.75
CPU: Intel Core i5-13400
GPU: NVIDIA Quadro P2200 5GB
RAM: 16GB DDR4 3200MHz
Operating System: Windows 11 Pro
Please investigate this issue. I believe it may be related to the new 8.76 update because this problem did not occur in version 8.75.
Thank you for your help.
OS: Windows 11
  •  0
  •  66
Submitted byanimationntxp2025
COMMENTS (0)
