| A. Adjust Size and Color. |
| B. Adjust Direction. |
A. |
Apply Spark_03, and select sub-object in the Scene Manager. Right-click on the iProp and select Perform/Effect On. |
Adjust the Key Size value of each Particle to 5 times in the Modify Panel. |
You can Adjust Particle Key Color value in the Modify Panel as well. |
For example, you can create the purple spark following the instructions below. |
| B. |
Adjust Direction |
There are 4 directions in Engine special effects.
Right-click on the iProp and you can choose the direction that you need. |
