For the ease of use and convenience, iClone is designed with the same mouse controls for both camera operation and object transformation. This method of control allows you to edit scenes with one hand on the mouse and the other on the keyboard, saving you from moving your hand back and forth among the keys.
Camera Tools |
Transform Tools |
Zoom In/Out |
Pan |
Rotate |
Focus to Selected - Perspective view |
Focus to Selected |
Walk/Fly Camera |
Select |
Move |
Rotate |
Scale |
Icons |
Mouse Operations
Roll Mouse Wheel Both Mouse Buttons |
Left Mouse Button |
Right Mouse Button |
Select the object and press the hotkey. |
Toggle Walk/Fly mode to navigate your selected camera view to specific spot. Press + or - to Accelerate or Decelerate the movement of the camera. |
In Transform Mode, single click on the target object. In Camera Mode, double-click to select the target object. In Select Mode, hold down the Ctrl key and single click on objects may Multi-select them. Alternatively, you may drag a box on the 3D viewer to enclose desired objects. |
Along X Axis: Left Mouse Button + Cursor Moves Left/Right Along Y Axis: Left Mouse Button + Cursor Moves Up/Down Along Z Axis: Roll Mouse Wheel |
Rotate Along Z Axis: |
Uniform Scale: |
Hotkeys |
Z |
X |
C |
Home |
N/M |
Q |
W |
E |
R |
Note: |
