When setting an iClone scene, it may be useful to draw a grid to represent the floor (X - Y plane).
If you want to show the grid in the 3D viewer, you may check the Show Grid box. Alternatively, you may press Ctrl - G shortcut to show/hide the grid.
Grid Off |
Grid On |
Your are allowed to change the color of the grid line by the color picker.
The default grid color. |
The grid color changed. |
You may also change the Grid Spacing value to decide the size of the grid cell .
The grid spacing = 50 |
The grid spacing = 100 |
The Gird Size decides the number of the grid cells on both sides of the gird.
Grid size = 10 |
Grid size = 2 |
Check the Snap to Grid box so that your objects always snap to the intersection points of floor grid when they are manipulated by the Move tool. (X, Y values only)
You may check the Angle Snap box and define the angle so that when your objects are manipulated by the Rotate tool, they rotate in a fixed angle each time.
Angle Snap= 45 |
