Swapping Special Effects
CrazyTalk provides an additional SFX track to allow swapping special effects between foreground and background.
  1. Double-click anywhere on the SFX-Swap track to apply special effects. You can also select part of the timeline to apply the special effect to that section only.
  2. Select a special effect (Default, Image Overlay or Text SFX are available). Click the OK button to leave this dialogue box.
  3. Play the project to view the result.
  4. Press the Black and White box next to the title of the SFX-Swap track to have the special effect move between fore- and background.
  5. Note:
    • You must specify the background mask of the image before seeing this change.
    • The other SFX track will always be on the top most layer overlapping the image.
