Grouping and Ungrouping
If you have a script with keys edited, you can select a partial sequence to create a custom motion clip for further use.
Grouping to create a motion clip
  1. Drag on the Motion Clip track to select a partial sequence.
  2. Right-click on the selected sequence and choose Group from the menu. You may also click the Group button.
    Before Grouping
    Selection on
    Motion Clip Track
    After Grouping
Ungrouping a motion clip
  1. Click to select a motion clip.
  2. Right-click on it and select Ungroup from the menu. You may also click the Ungroup button. The keys in the motion clip will be dissected and can then be edited individually.
  3. Note:
    If the property boxes of the motion clip are checked, ungrouping a motion clip will keep the keys in the overlapped area.
