Motion Clip Property
After a motion clip is inserted, right-click on it and choose Property from the menu, or double-click on the caption of the motion clip in the motion clip track. You are prompted with the Motion Clip Property panel. The Motion Clip Property settings determines how CrazyTalk processes the overlapped clip area, replacing or mixing with the keys of the underlying tracks.
  • Check the individual checkboxes so the keys that are overlapped by the motion clip are also used to determine the motion of your character.
  • Adjust the Length slider to specify the speed of the motion clip.
  • Adjust the Strength slider to specify the strength weight of all the keys in the motion clip. The default value is 50%.
  • Click the Preview button to preview the result of the settings in the panel.
  • Mixing Principles:
    A prepared motion clip is about to be
    applied to the timeline that already contains keys.
    Face Track: Unchecked. The keys on the
    timeline are replaced by the ones in the
    motion clip.
    Face Track: Checked. The keys on the
    timeline are blended with those in the motion clip .
