Creating and Adding Motion Clips
Creating Motion Clips
Adding a Motion Clip to the Gallery
  1. Please toggle the Motion Clip tab in the Script page.
  2. Select a desired motion clip in the Motion Clip track.
  3. Click the Add button or right-click on the selected motion clip and choose Add Clip from the menu. (Ctrl + Shift + S)
Converting and Adding a Time Sequence into a Motion Clip
  1. Drag on the Motion Clip track to select a partial sequence.
  2. Right-click on the selected sequence and choose Add clip from the menu.
  3. The sequence will be converted into a motion clip and added to the gallery.
Note:
  • If you click the Add button while holding the Shift key, CrazyTalk saves the SFX images of each frame in BMP format, which can accelerate the saving speed but increase the size of the motion clip.
