Defining Background Mask for Entire Character
The wire frame of each model is divided into two parts, the Character Frame and the Head Frame.
Character Frame
  • The Character Frame (quadrilateral wire) defines the primary mask of the whole project.
  • As soon as the background is set to a solid color or image, the part of the project covered by the primary mask is replaced with the color or image.
    Character Frame
    Primary Mask
    (Screen Area)
    Primary Mask
    reveals
    Background Image
  • You may modify the four corner points in the wire frame mode to define the primary mask area.
    Character Frame
    Modified
    New Primary Mask
    New Primary Mask
    reveals
    Background Image
  • Fine-Tuning Background Area with Background Mask
    Since the primary mask defined by the Character Frame can only be quadrilateral, you may use the Background Mask Editing feature to fine tune the area that will reveal the specified background image. Please refer to Editing the Background Mask and Configuring the Background Settings for more information.
    Part of
    Background Image
    Revealed by
    Primary Mask
    Fine Tune the Mask
    in
    Background Mask
    Editing Panel
    Result
