If the original image has no teeth displayed, you can add virtual teeth that are displayed when the mouth is opened. Click the Teeth tab in the Advanced Facial Settings menu to add virtual teeth and adjust their settings as follows.
Check the No Teeth box if you do not want to add teeth to the mouth. If the original image already has visible teeth, check this box.
If you want to use any of the virtual teeth available from the teeth templates, select a set of teeth from the gallery. The new teeth are immediately displayed in the preview window.
To set the size of the teeth, use the Scale feature. Move the Dense/Sparse slider bar to adjust the width of the teeth in the mouth. Move the Short/Tall slider bar to adjust the height of the teeth.
To specify the position of the teeth in the mouth,
use the Displacement feature.
Click the
arrows to move the
teeth. Click the Reset button
to clear the displacement settings and start adjusting again.
Click either button of Rotate, you can rotate the teeth. Keeping the mouse pressed can continue the rotating.
Use the Color Settings feature to choose the color of the teeth. Move the Brightness, Contrast, Hue, and Saturation slider bars to adjust the teeth color. Alternatively, enter a number in the boxes next to the slider bar to change the parameter value. Click the Reset button to clear the color settings and start adjusting again.
Click OK when done.
Note: |
