Creating Custom Teeth
You may create your character's teeth by importing a custom teeth image:
Before Importing Custom Teeth Image
  1. Click Import button.
  2. Locate the texture image for the virtual teeth. (jpg, bmp, tga, png are supported. 256 pixels x 166 pixels recommended)
The teeth image, in PNG format, containing alpha channel
(The part displayed in check board pattern)
Note:
  • If you import an image in 32-bits BMP/TGA, the black part in the image will be converted into the alpha channel.
  1. Click Open to apply.
After Importing Custom Teeth Image
The part with alpha channel will be transparent
to reveal the color inside of the mouth
