Transforming Sprite Elements
Each element in a sprite has different sizes and angles. But if you need to
align, rotate or scale the elements, then you may do this in the Composer.
This task is helpful for
Sprite Switch Animations.
Please select a prop and click the Prop Composer button in
Stage Mode.
In the Composer Mode, pick the sprites of the prop.
Click the Sprite Editor button on the left-side
tool bar. All the elements are listed in the panel.
Please refer to the Preparing a Custom Sprite section for more information about adding more elements to the sprite.
In the list, pick elements one by one to review their position,
size and orientation.
You may see the green transform handle box shown around the
element.
Move your cursor to the inside of the box. Drag to relocate the
element.
The area for moving
Drag the eight control points around the box to scale the
element.
Please note that the four corner points proportionally scale the element
while the points on the sides do not.
Drag the rotation area outside the box to rotate the element.
The area for rotating
Modify the transform point of each elements until they are all aligned.
Note:
When editing, constantly pick other elements of the sprite in order to correctly align all the elements.
