You can load different types of media, videos or images to create a sprite. When a sprite contains a series of image or videos, then you may create Image Replacement Animations in Stage mode with setting keys.
If you want to create a sprite, or append more media onto an existing sprite, then you may use the two methods below:
The possible look of the body part |
Different possibilities for a prop |
Note: |
