By default, effects are animated as a looping animation.
You may adjust them to specific times and sizes.
Drag an effect into the Stage. Under 'Scene Manager' you will see the name of the effect showing with the number '258' which is the effect's frames.
Right-click the effect and select Sprite Editor and open it. Select the Effect icon in the window instead of the Position icon. The effect will be activated.
3
You may also open the Timeline window to type in a specific time frame to change the animation. You will see a key on the frame once you change the animation.
