How to apply effects to vehicles
How to adjust animated effects on the Timeline
How to adjust animated effects in the Timeline?
By default, effects are animated as a looping animation.
You may adjust them to specific times and sizes.
1 Drag an effect into the Stage. Under 'Scene Manager' you will see the name of the effect showing with the number '258' which is the effect's frames.
2 Right-click the effect and select Sprite Editor and open it. Select the Effect icon in the window instead of the Position icon. The effect will be activated.
3 You may also open the Timeline window to type in a specific time frame to change the animation. You will see a key on the frame once you change the animation.
Copyright © 2012 Reallusion, Inc.
