Action |
Hotkey |
Notes |
Move |
W or Up Arrow Key |
Move Forward. |
S or Down Arrow Key |
Move Backward. |
Shift + A/Left Arrow Key |
Move Leftward. |
Shift + D/Right Arrow Key |
Move Rightward. |
Shift + E or Page Up |
Move Upward. |
Shift + Q or Page Down |
Move Downward. |
Ctrl + Click on Terrain |
Move to given location. |
Ctrl + Double click on Terrain |
Run to given location. |
X |
Switch to Previous Move Mode. |
Z |
Switch to Next Move Mode. |
Rotate |
A or Left arrow key |
Turn Left. |
D or Right arrow key |
Turn Right. |
Q |
Turn Up. |
E |
Turn Down. |
Perform |
1 ~ 0 |
Proceed perform presets 1 to 10. |
Operate |
Ctrl + Left Mouse Button click/double-click on iProp |
Proceeding the default Operate motion of the target iProp when the focus is on the actor. e.g. get in the car |
Select Target |
Shift + click/double-click |
After you switch a target, the follow cam snaps to view the new target. |
Pointer |
Ctrl + I |
Show/Hide Pointer. |
Switch Follow Camera |
F7 |
Toggle between follow cam-actor and follow cam-bird. |
Mode |
ESC |
Exit the Director Mode. |
You may follow the instructions below to customize your own shortcuts for the Director Mode. It is highly recommended that you keep a copy of any file before you modify it.
Please open the AMLHotKey.ini with text editor in C:\Program Files\Reallusion\iClone 4\Config.
Follow the rules to modify the content of this file.
The ini file supports alphabet, digits, Alt/Shift/Ctrl, Up/Down/Left/Right and Insert/Delete/Home/End/PageUp/PageDown.
Only Alt/Shift/Ctrl can be used for combination keys and use '+' to connect them.
If the defined key conflicts with iClone's function keys, the function will not work.
IClone reserved keys: F1 ~ F12 (function keys), Ctrl + P (Preference Panel), Ctrl + F (FPS show/hide), Ctrl + G (Grid on/off), Spacebar, Back space, Enter, Esc, Tab, \, /, [, ], +, -, Numerical Keypad (same as normal number keys).
Save the ini file and re-launch iClone to validate these settings.
