Time Setting Panel
The Time Setting panel enables you to adjust the Length and Time Unit of the project. Click the clock button next to the current time counter below the 3D view port window to open the Time Setting Panel.
This button opens the Time Setting dialog box for further adjustment.
Tip:
  • If you intend to set desired project length as the default length, please switch to Project/Modify page and click Set Default button after you change the Animation Length in this panel.
