Introducing the Face Key Editor
Bringing up the Key Editor
The face Key editor facilitates setting or modifying keys in the Head, Face or Eyes tracks by using a more intuitive and interactive interface. To bring up the Face Key Editor, you may:
The Face Key Editor is divided into four tabs: Facial, Template, Modify and Custom.
Facial Tab
1. Add/Modify Head Key
Select to rotate / tilt the head.
2. Solo Feature Selection
Select to highlight the desired features and convert the changes into keys.
3. Default Key
Click to set keys and neutralizes all adjustments made to facial features.
4. Clear Selection
Deselect all features.
Template Tab
1. Expression Style
Use the drop-down list to switch to a different expression template library.
2. Expressiveness
Drag the slider to decide the strength of the applied expression template.
3. Add
Click this button to generate a custom template and add it into the library.
Modify Tab
1. Solo Feature Strength
Drag the sliders in this pane to set a key to the individual facial offset features.
2. Expressiveness
3. Add
Custom Tab
1. Custom Library
Stores all custom face-key templates.
2. Expressiveness
3. Add
4. Delete
Click this button to delete a selected custom template from the library.
