Creating Custom Puppet Profiles
Create your own, unique puppet profile or modify existing profiles
with the Advanced pane.
Creating and Saving Custom Profiles
Click the Clear Selection
button to deselect all features.
Pick the desired features in the Solo Feature Selection pane.
Click the Preview button, press the
Space bar, and move your input device (mouse by default) to preview the movements of the selected features.
If you are satisfied with the results, then click the Save
Face Animation Profile button to save
your custom profile.
Adjusting Weight
To customize your own puppet control profile, then you may need to manually adjust the weight of each feature.
Click the Advance button to expand the weight pane.
Modify the values in the Weight column, of the corresponding feature, to specify
the weight movements triggered by your input device (mouse).
Repeat Steps 3 and 4 until you obtain satisfying results.
Click the Save
