CrazyTalk Animator can also animate through text-to-speech engines. By default CTA is connected to Microsoft's TTS (Text-to-Speech) engine, but users may incorporate their own additional engines if they wish to. Users create their own talking script for any model.
CrazyTalk Animator supports SAPI compliant Text-to-Speech engines. CrazyTalk Animator uses the Microsoft TTS engine as this has 19 voice characters available. If you currently only have one voice installed (default), then other voice types are direclty available from Reallusion's site https://www.reallusion.com/mtts.asp, or visit Microsoft's website.
Follow the below steps to create an audio script:
Type the text in the editor window. Alternatively, you may also copy and paste text from any word processing program.
Select the type of voice to be used by the model by choosing in the Voice Mode drop-down list. Various voices for both sexes, with different settings, are available.
Adjust the voice by using the Volume, Pitch, and Speed sliders to achieve the desired effect. You may also enter a number value directly into the boxes next to the sliders. You may need to experiment a little with these settings before you get the desired results. Click the Reset button at any time to reset the sliders to their default values.
Click the
Preview button to play back the text.
Click the OK button when done.
