Changing the Layer Order of Sprites
After creating a prop with multiple sprites, you may adjust the sprite layer order in a compound prop
with the Prop Composer.
You may arrange the visual logic of the prop as seen below.
Before adjustment
After adjustment
Select a compound prop. Click the
Prop Composer button to enter the Composer Mode.
Switch to the Layer tab in the Scene Manager.
Select the item for which you want to change the order.
Click the Move to top, Move up,
Move down, and Move to bottom
buttons to re-arrange the order of the selected item.
You will be able to instantly see the changes inside the working area.
Repeat the steps until the look of the prop meets your visual logic.
