Transforming inside the Working Area
When you wish to set transform keys for a character or a prop inside the working area, then just use the Mouse Dragging and Transform Tool methods.
Mouse Dragging
After you select a character or a prop, a transforming handle box will automatically appear.
Click and Drag with the left-mouse button on a different area in order to perform different transformations. A transform key will then be added:
Dragging inside of the box: Moving in the working area.
Dragging on the icon : Moving on the Z axis.
Dragging outside of the box: Rotating the character or the prop.
Dragging the four side-points: Resizing the character or the prop.
Dragging the four corner-points: Resizing the character or the prop while keeping the same aspect ratio.
Please note that the four corner-points proportionally scale the element while the points on the sides do a non-proportional scale.
If you need to set a transform key with an exact value, then click the Transform button.
X, Y, Z: Enter these values to decide the location of the character or the prop.
W, H: Enter these values to decide the Width and the Height of the character or the prop.
Lock/ Unlock; Press this button to toggle the Keep Aspect Ratio on/off.
: Enter value to decide the orientation of the character or the prop.
Switch between the and buttons to change the path from
curve to a straight line.
Click the Default Key button to set a neutral transform key (0 value) to each numerical field in the panel.
