Setting the Face Keys
Using the Facial Tab
Select the desired
facial features to set keys in the pane.
If you are using the mouse as your input device, then press and hold the left-mouse button inside
the interactive area.
The Interactive Area
Drag the mouse in the interactive area to make the changes.
Using the Template Tab
If you do not want to set an expression, one facial feature at a time; then it is recommended that you use templates. Especially for
Sprite-based faces.
Switch to the Template tab.
Select a category from the Expression Style drop-down list.
If you are using the Sprite-Based face, then you may also select the
For Comic category.
In the Template Library pane, click on the desired template.
Change the Expressiveness values to adjust the strength of the applied expression.
Using the Modify Tab
If you use the Facial tab to set facial keys, then you are actually modifying the values of each slider in the Modify tab.
Therefore, you can use the sliders inside of this tab to fine-tune the values for each facial feature.
Switch to the Modify tab.
Drag the slider to change the value, the selected character will then change the facial expression accordingly.
Note:
Please note that each template is a combination of different values from the facial feature sliders.
