Introducing the Export Page
CrazyTalk Animator now offers the convenient feature of exporting your project into multimedia formats that are compatible with a wide range of devices. For instance, you can now convert your work to an AVI file with DVD and HD quality. You can also convert it into sequenced image (BMP/JPG/TGA/PNG) files to broadcast on a web server. Exporting Flash files is also supported so you may output your projects as flash animation.
A. Media Types
Mode Tabs
  • : Output Video/iWidget/PopVideo/Wave Files.
  • : Output Sequenced Images and GIF Animation Files.
  • : Output FLV or SWF Files for Web.
B. Format and Quality
In this section, you may choose the image, video and audio quality output.
Note:
  • By default, the export format is WMV; however, if you want to further edit the exported video with an external video editor, the please choose AVI RAW data for lossless post production; this maintains color fidelity for high quality production.
  • For more information about WidgetCast, please refer to https://www.reallusion.com/widgetcast/help/
  • For more information about PopVideo, please refer to the popVideo Converter Online Help.
  • If you wish to export as a Gif Animator, iWidget or popVideo with transparent background, then please remember to set the background in solid color.
  • If you want to export into a WMV file format, then you will need to first download and install the WMVEncoder9 from the Microsoft website.
C. General Settings
In this section you may set projects as 3D media and set other general settings.
D. Export Tools
Export Buttons
  • : Click this button to preview the current frame results.
  • : If you have installed Reallusion WidgetCast, then this button will be enabled. You may then click it to export your project directly into this program.
  • : Click this button to export your project in accordance to your settings.
