Animated Effects 3 includes 32 cool new props animated with various SFX to help you add a more dynamic element to your story or presentation. Check out the instructions below for more on how to use these little content gems.
How to Use Animated Effects
1. When you right-click on any of the props in this pack, you will have 3 available options once you open up the Action Menu: Start, Loop, and End.
2. Start contains the first stationary frame, while End contains the last stationary frame. The Loop option contains the entire animation.
3. The loop action will only play one time, but you can drag the clip's right edge rightward to repeat the clip.
Copyright © 2014 Reallusion, Inc.
