Indigo Render Plug-in
Physically Based & Photorealistic Renderer
A photo-realistic, cinematic look and feel in iClone is now a reality with this iClone Indigo Render Plug-in. Utilize GPU accelerated raytracing render capabilities in Indigo RT, your characters, props, and scenes now look completely different from before. To streamline this unique workflow, Reallusion provides automatic shader mapping between iClone and Indigo. In addition, users can perform custom refinement using Indigo's unique shader options, or download Indigo's material library to achieve even better results. Skylight and emissive material settings ensure correct global illumination, and allow for realistic light behavior via reflection, refraction, transmittance, and caustic effects. Furthermore, the physical camera DOF and tone mapping system can be combined with excellent lighting and materials to create vivid and astounding story visuals like never before!
rendering software
DISCONTINUED PRODUCT
Light from iClone
You are able to determine if you want to use the lights in the current iClone project, or if you want to use the default light provided by Indigo to render the entire scene. If you want to add additional lights from iClone for rendering in Indigo, select one or more lights, determine the desired sizes of the lights, and then export them along with the project to Indigo.
Lights in iClone
Adjust lights before exporting to Indigo
Lights in Indigo
Indigo Emission Light
In Indigo world, any object can magically become luminous as long as you turn on and adjust the Base Emission function. Base Emission parameter specifies the base amount of light a material emits (in units of Lumens), which can be modulated using the Emission parameter. This is used to create light sources. While the Emission parameter multiplies the Base Emission to produce effects such as TV screens, where the brightness varies over the surface of the screen. An emission scale parameter is available to scale the emission of the material by a given amount. Various photometric units are available.
  • slidebg1
    Indigo Sun and Sky
    Indigo features an advanced sun & sky system based on the highly accurate atmospheric simulation.
    Computed directly from the physical laws which produce blue skies and red sunsets in nature,
    this system produces extremely realistic skies at any time of day; not only is it realistic, but it also
    renders fast.
  • slidebg1
    Indigo Sun and Sky
    renders fast.
  • slidebg1
    Indigo Sun and Sky
    renders fast.
  • slidebg1
    Indigo Sun and Sky
    renders fast.
