popVideo Converter
Reallusion popVideo Converter turns video or image sequence (with Alpha Channel) into a video with transparent background (popVideo). Real human, pets, comics, or animation all can become an impressive virtual host for your business. By working with iClone or WidgetCast, it gives you the edge to immerse any real-life actor into 3D environments & web. |
Key Features:
• Turn the video format (AVI, WMV) and image sequence (JPG, BMP, TGA, PNG) into the video with transparent background (popVideo in iWidget format)
• Bring your chroma key video to 3D world for post production or web & desktop output
• Easier to manage the video with transparent background in one file
• Ensure the synced chroma key video playback in program
| popVideo Converter |
$ 99.95 Full Version |
popVideo for Web |
WidgetCast PRO +
popVideo Converter
$ 249.95 (List Price:299.90) |
| * Login to Member Special for iClone & CrazyTalk Users from $149.97. |
- In order to get a video with the clean background, you are suggested to shoot your model or product on the green or blue screen (or paper with single color). To get the cleanest background, the biggest challenge is even lighting and the avoidance of shadow, because it is best to have as narrow a color range as possible being replaced.
- Chroma key is a technique for mixing two images or frames together, in which a color from one image is removed (or made transparent). Your first step to create it is to place your source clip on the timeline of any video editor. Then, drag the Chroma Key effect onto the event. In this step, you will need to create a mask file (purely black and white) from your source file.
- Now, open your popVideo Converter and import your source and mask files to the converter. And you can export a popVideo in iWidget format. Please note that this output (popVideo) can only be used in WidgetCast for live publish since it's designed as Flash media.
| Output for iClone |
popVideo Converter creates & ensures the chromakey video playback in iClone that allows you to manage and bring any real-life actor into 3D environments.
| Output for WidgetCast |
popVideo can turn any real-life actor with transparent background on the web (popWidget) which can grab your viewers attention and get the Highest Click-through-rate.
