With iClone4, you may insert a video into texture channels and place it on the surface of any 3D object.
The supported video formats are:
AVI, WMV, MPEG.
FLV, iWidget, popVideo.
Any video that can be played with corresponding video codec on your computer.
The methods to apply videos are:
Drag-and-drop: You may drag a video onto the target face of one object (terrain and image layer excluded) in the preview window to replace its image of Diffuse channel.
Loading from Channels: If you want to apply videos into either channels, you may double-click on the channel and locate the desired video. Please note that for the Image Layer object, you only can use this method to replace its diffuse texture.
Use the video as texture channel for particle system and you can get more natural and dynamic visual results.
After adding a video, you may decide when the video starts, pauses or stops by setting keys to it.
By working with other texture channel (image or video) and material key, the videos can be enhanced with dynamic glow, bump, reflection and other filtering effects.
See popVideo | Virtual Set | HDR Video
Back to Feature Home
| Privacy Policy | EULA | RSS Feed | Site Map Copyright © 2009 Reallusion Inc. All rights reserved. |
