Apply life-like motion capture animation from a vast library of motion options for body language and natural human movement.
Create custom poses and animation with full rotation and transformation of each bone (IK & FK).
Multiple-actor dialog support to create simultaneous conversations. iClone4 PRO edition contains multiple voice track timelines for quick dialog editing.
iClone4 Standard edition supports multi-actor dialog with playbar segment editing.
Automatic alignment of applied motion makes it easier to align several motions.
Quick tab editing from the playbar jumps to the start or end of each motion segment using the tab or shift+tab keys. Locate and replace motions easily from the playbar.
Actor 'Look-at' enables the actor's face and eyes to follow a specified target object or always look at the camera. Adjust the weighting between eye movement and head movement to fine-tune the effect.
Link and attach scene objects to actors.
Directly pick an actor to attach any prop as an accessory.
Simply link and unlink an actor to a car, a horse or other vehicle or mount. Link and unlink objects such as a ball and throw it from the hand or to another actor.
Direct in-scene motion editing, picking and manipulating of any selected bone using Forward Kinematics (FK), and Inverse Kinematics (IK) to adjust motion. (No external Motion Editor required.)
New! Motion Reverse - reverse the motion to make a loop or special backward video effect.
Motion Layer allows the flexibility to add a modification layer over existing motion. The Motion Layer extends the motion creation and fine-tune process with the ability to either create 100% custom motion or use the Motion Layer to enhance existing motion clips.
Complete Motion Building and Editing in the Timeline Editor including key pose creation, mocap data blending, loop generation, speed adjustment, foot alignment and copy, paste or deletion of motion segments. Use the Collect Clip function to export any selected motion segment and save them to the motion library.
Note: Previous users of iClone 2.x or below still may opt to use the legacy Motion Edition. However the method of Motion Building in iClone4 PRO is far more superior.
New! Hand gesture quick editing and individual track control. Edit the actor's fingers in chorus to easily grab and bend fingers separately.
See Facial | Interactivity
Back to Feature Home
| Privacy Policy | EULA | RSS Feed | Site Map Copyright © 2010 Reallusion Inc. All rights reserved. |
