v3.2C (3.2.1526.1) released 26 March-09
- Fixed: Crashing issue occurs when the grass just added into the Scene Manager is picked as the project is playing back.
- Fixed: The left and right facial mappings are opposite between iClone and CrazyTalk.
- Fixed: In Director Mode, iClone crashes when Ctrl +Click an iProp with no Move Command embedded.
- Fixed: Animated Texture effect is rendered incorrectly in the Quick Shader Mode. (E.g. The talking bubble in the Language Learning project)
- Fixed: The blending part of a clip in the timeline fails after being shrunk and extended again.
- Enhanced AML script:
- 1. Sub-prop control enhancement
- 2. New FullStop state for Move Command.
- Enhanced: Smaller watermark for EX version.
- Enhanced: Real-world camera setting (35mm format)
v3.2 released 29 December-08
- Enhanced: Performance enhancement on computers with multi-core CPUs.
- Enhanced: Option to launch your video player after video output is finished.
- Enhanced: "Align Actor Motion" option under "Animation/Motion" is checked by default now.
- Enhanced: Updated the BackStage program icon.
- Enhanced: The "Show/Hide" status of all items is now saved when a project is saved.
- Added: iClone data files now support thumbnail displays (when browsing for files for example)
- Added: "Lock Ratio" option for UV editing under "Material & Texture Settings".
- Added: "Effect All Channels" option for UV editing under "Material & Texture Settings".
- Added: Default Content - 3D Spaces under Props
- Added: Default Content - Artificial Eye uner
- Added: Height adjustment for Sky props
- Fixed: CloneCloth Caracters did not display "Drop" and "Wall" shadow effects properly in Pixel-Shader mode.
- Fixed: CloneBone characters with parts already attached could not be loaded.
- Fixed: Loading iClone2 projects would display all particle effects at twice the speed.
- Fixed: Loading projects would sometimes not open the reminder message to save your current project.
- Fixed: Saving a project would use the current view for the thumbnail of this project.
- Fixed: Trinity's eye color could not be adjusted.
- Fixed: e-mail addresses with too many characters could not be used to log into iClone3 EX.
- Fixed: The "Jeep" iProp could not be animated using the right-click commands on iClone3 EX.
v3.1 released 21 November-08
- Added: iClone BackStage Live Content Access
- Added: WidgetMe (Beta) - transparent Flash movie for the web
- Added: Flexible spring for natural movement
- Added: Material key frame editing and animation
- Added: AML templates and interactivity
- Added: Hair offset for character
- Added: Drop Shadow and Wall Shadow supported
- Enhanced: CloneBone character system
- Enhanced: Facial animation
- Enhanced: Material Pick and UV offset/tiling
- Enhanced: Reduce iClone loading and speed up program initialization
- Fixed: Crashed when loading iClone 2.5 projects with no character
included.
- Fixed: "invalid project" warning appeared when loaded projects
from some previous versions.
- Fixed: AML script errors on props and characters
- Fixed: Undo & Redo caused crash in some conditions.
v3.03 released
15 September-08
- Fixed: For graphics cards that only support Quick
Shader, application crashed during final render in some condition.
- Fixed: Crashed when users chose Head>Texture>Diffuse>
Launch Editor, then back to iClone and select Glow>Launch Editor.
- Fixed: Director Mode using W.A.S.D. keys to move character and
camera at the same time, the character would be reset to the original
position.
- Fixed: Application crashed when using iClone 2 motion with Sample
Transform.
- Fixed: Removed redundant materials.
- Fixed: Some old prop content appeared incorrectly in iClone3.
- Added: Timeline tab keys - Tab: next key; Shift+Tab: last key.
v3.02 released
28 August-08
- Fixed: Non-English language issue, caused character
damage and unable to apply motion
- Fixed: Non-English language issue, chose
Actor/Special, applying body style caused crash
- Fixed: Geforce FX 5200, Quick Shader, export BMP format with final render caused lockup
- Fixed: In Hand Combat project, changing character caused crash
- Fixed: Apply G2 character, select Head/Face/Modify/adjusting
face feature, drag scroll bar caused crash
- Fixed: Exporting project with GIF animation
800x600 caused crash
- Fixed: G3 character applied G1 object, undo
and redo caused crash
- Fixed: [Content Pack] Wedding Planner pack > Minister, open Groomsman caused crash
- Fixed: [Content Pack] Filmset and Props > 3D Scene, open Classic Living Room caused crash
- Fixed: [Content Pack] import iClone Theme
Pack > Horse & Tack, open some props caused crash
- Fixed: Obvious user interface defects
- Fixed: Default content defects
- Fixed: Glow Map disable issue
- Fixed: Click expand (+) and clap (-) on Scene Manager/Lighting caused crash
- Fixed: Most of the content pack compatibility issues
- Fixed: Cannot output a TGA file with the alpha channel
- Fixed: Director Mode, operate command caused crash on some objects
- Fixed: Some imprecise messages
- Fixed: Click Mouth/Light/Head caused crash in some conditions
- Fixed: Two characters looking at each other caused unnatural head movement
- Added: Provide horizontal scroll function on Timeline Editor
- Added: Disable Vertex Shading and Pixel Shading when the graphic card does not support
- Enhanced: MP4 export quality
- Enhanced: Graphic Card compatibility on Intel, ATI (HD3650), nVIDIA(GeForce6 Series)
- Enhanced: G2 character mouth movement and visual quality
v3.0 released
09 August-08
- Added: Two production modes: Editor Mode and Director
Mode
- Added: Scene manager for total project asset list and access
- Added: Right-click menu system
- Added: Undo/Redo
- Added: New G3 Character
- Added: Facial Normal Map
- Added: Direct 3D object manipulation
- Added: Attach and Link (scene objects to characters)
- Added: Dramascript XML mod scripting for creating custom actor
and object interactivity
- Added: Direct actor motion editing, FK, IK (No external Motion
Editor required)
- Added: Tab track editing
- Added: Multi-actor timeline editing for Pro users
- Added: CrazyTalk5 auto lip-synch compatible
- Added: MP3 Import
- Added: Multi-camera system
- Added: Enhanced lighting system
- Added: Material Editing
- Added: Terrain + Sky + Grass, Water & Foliage Scene builder
- Added: Multiple Shader selection and preview options (Wireframe
to Pixel Shader)
- Added: Flash Output
v2.5 released
22 October-07
- Added: Direct Picking and Manipulating Selected Objects.
- Added: Add Linkage between Objects and Characters.
- Added: Large Scene
Camera.
- Added: New demo Project.
- Added: Press the "E" key to quickly auto level the
camera back to the upright position if the camera gets tilted.
- Added: Press the "F" key to zoom the camera view to
the front of the selected object.
- Added: Press the "Home" key to view the selected object
from top right position.
- Added: Rotate and orbit camera to the “F” or “Home”
keys focused objects.
- Added: Camera templates for medium, large and extremely large
scale scenes. Film large cityscapes, terrains, architecture and
more.
- Data Fixed: Jack CloneCasual fails to adjust color.
- Data Fixed: Jack Casual 's shoes under floor board.
- Data Fixed: The finger become too long after the body size
is adjusted.
- Data Fixed: Some illegible node name is modified to be more
readable.
- Enhancement: The ears can be modified to be more distinctive.
- Enhancement: Default pose become more than upstanding.
- Program Fixed : Crashing problem when wav file is imported and
then export the project to an avi file.
- Program Fixed : Crashing problem when all props are removed
and reverted.
- Program Fixed : Fail to apply teeth or eyes when non-standard
character is applied and replaced with G1/G2 character.
- Program Fixed : The face fails to receive light in the final
export result after specific dynamic light is applied.
- Program Fixed : The hands collapse after some certain motions
are applied to the character.
- Program Fixed : The hair has mistake in quick shader render
mode.
- Program Fixed : Crashing problem when user apply gesture on
timeline (18000 Frames) and click fit to windows.
- Program Fixed : To improve character posture include :
- G1 Character
F_Explorer
M_Dabu
M_Football
M_Hero
M_Surfing
F_HipHop
F_NewsAnchor
M_ManInSuit
F_SexyDancer
- G2 Character
Jack Clone Casual
Jane Clone Casual
v2.1 released
03 July-07
Added: Vista support - iClone 2.1 works with Windows Vista.
- Program Fixed: Fail to apply hand gestures to G2 characters. Click
to view
- Program Fixed: Visual defect in the facial texture adjustment
for certain hair style. Click
to view
- Program Fixed: Fail to export AVI video. Error Message "Cannot
initialize video encoder; export failed."
- Data Fixed: Updated default Jane Casual character with a better
face shape and hair style.
- Data Fixed: Fail to adjust color on Jack Casual's shoes. Click
to view
- Data Fixed: Fail to apply accessories - Microphone. Click
to view
- Data Fixed: Remodel Jack CloneCloth Casual character to remove
the extruded chest. Click
to view
- Data Fixed: Remove shoulder joint twist for certain motion data
(list below). Click
to view
Fun\Comedy
Dance\Hiphop02
Dance\Hiphop04
Dance\Hiphop07
Dance\Rock and Roll
v2.0 released
21 March-07
- Added: G2 Character - enhanced bone structure
and texture details
- Added: G2 CloneCloth Character - dual-layer, custom garment
design
- Added: Be able to save accessories with custom Characters
- Added: Particle Effects - full control over particle parameters
- Added: Fog
- Added: LivePlants for 3D Scene
- Added: Foot sliding removal
- Added: Multi-channel textures export
- Added: HD video size output - 1280 x 720 (720P), and 1920 x
1080 (1080P)
- Fixed: Black and white slanting video in Avi format is exported
when user key in specific dimension
- Fixed: Crashing as the Insert key on the keyboard is pressed
while any Template Folder in File Manager is focused
- Fixed: Crashing when beta Effect Pack is loaded and applied
- Fixed: Incorrect display of Motion Total Frame
- Fixed: Wrong tag name in Modify page of Accessories
v1.52 released 04 October-06
- New: Speed up rendering speed from 2x to 20x
- New: Select video compressor before exporting video
files
- New: Be able to export AVI up to 2GB in FAT32 format
hard disk.
- New: Now be able to export AVI larger than 4GB
with NTFS format hard disk.
- New: Convenient Hotkeys for Move, Rotate Character
and Offset Character Shadow.
| Function |
Hotkey |
| Move character |
Alt+up/down = move (Z)
Alt+right/left = move (X) |
| Rotate character |
Alt+left/right = rotate (Y) |
| *Offset Character shadow |
Ctrl+up/down = move (Y) |
| Tips - Speed character movement: combining
"Shift" key to 10 times increase the character
movement or rotate speed |
- Fixed: iClone launch failure message.
- Fixed: Lighting color doesn't change after light
template is applied.
- Fixed: Sound volume sync problem between System
and iClone sound recorder.
- Fixed: iClone crashes when exporting WMV or AVI
files with certain 3D graphics cards.
- Fixed: Under some circumstances, hands will become
strange shape after users enlarge hands.
- Fixed: To eliminate the beeping noise at the end
of exported video files.
- Fixed: Fix Hero's neck connection problem.
v1.51 released 16 August-06
- Fixed: Increase the load speed of thumbnail images
- Fixed: correct the initial offset problem in walking
motion files
- Fixed: Hotkey changes - see Performance Issue
and Tuning in iClone1.5 manual
- New: Be able to turn off the warning message when
load projects without standard characters (press Ctrl-Shift-L)
- New: Add a high-resolution 3d sphere in \Props\3D
Blocks\
v1.5 released 1st August-06
- New: Real-time Pixel Shader supporting the following
visual effects
- bump map
- normal map
- reflection (environmental map)
- alpha channel (opacity map)
- self-cast shadow (nVidia only)
- vertex color
- UV texture animation
- particle effects
- New: Multi-texture Editing for characters and
props
- diffuse, bump, opacity, reflection, glow map
- planer, box, spherical, cylindrical, texture UV mapping
- New: Animation Tracks and Timeline Control
- camera, lighting, hands, animated props, animated accessories,
3D
- New: Preinstalled Content
- 3D Blocks System ( 45 items in 7 categories)
- 3D Surface System (4 items)
- 3D Billboard (1 item)
- 3D Architecture (6 items)
- Texture Library ( 43 items in 5 categories)
- New: Motion Editor 1.5v (Studio only)
- numerical joint data input
- align whole motion - anti-foot sliding
- reset pivot: lock pivot to the same XY location, prepare loop
motion for timeline animation
- fixed: copy and paste joint rotation to the whole motion segment
- New: BVH Converter (Studio only)
- be able to define BVH profile, convert and fine tune BVH motion
data
v1.01 released 8th February-06
- New: Complete content thumbnail in trial version
- New:"Content Developer Info" button
- New: Screensaver loading status
- Fixed: Screensaver loading defect
- Fixed: Trial version splash defect
v1.00 released 8th December-05 |
